  • Board index ‹ Technical - General ‹ Electrical, Ignition & Engine Mngmt
Pinto vs xflow starters
3 posts • Page 1 of 1
Postby atd350 » Sat Oct 06, 2012 11:03 pm
Hi all, can I use the same starter for both engines? I am wiring up now for an old school xflow starter and external solenoid On a 1600. But plan to swap in a pinto soon. So the question is, can I buy a new style pinto starter and use it on the xflow? That way no wiring changes later, plus more reliable/ powerful starting going forward. Any help is much appreciated. Cheers
atd350
Re: Pinto vs xflow starters
Postby ozstang65 » Sat Oct 06, 2012 11:09 pm
No, totally different, but through careful planning you could probably use the same wiring.
Postby Miniliteman » Thu Oct 11, 2012 12:56 am
Hi,
if you use a pre-engaged ringgear (135 teeth) and an alloy bellhousing you can use one of the reduction starters from a Sierra or Scorpio (pinto engined, don't know if you have these models). This is what I have on the BDA.
Leon.
Miniliteman
Return to Electrical, Ignition & Engine Mngmt
