  • Board index ‹ Technical - General ‹ Brakes
Steel vs Stainless Steel for brake lines
3 posts • Page 1 of 1
Postby ozstang65 » Fri Jan 13, 2012 11:27 pm
Looking for opinions, pros and cons for both materials when manufacturing brake hard lines. Cost is not an issue.
Re: Steel vs Stainless Steel for brake lines
Postby Clayton » Sat Jan 14, 2012 10:04 pm
I've used both, bundy tubing is much easier to form a good double flare. The proper brake S/S bends easy enough, but to get good concentric double flares is harder, even with a high end flaring tool. If you're not after the "look" stick to bundy tubing, my 10c
Clayton
Clayton
Postby ozstang65 » Sun Jan 15, 2012 9:43 am
Thanks Clayton, I'm not worried about the looks, it just has to do the job.
Cheers.
Return to Brakes
