Looking at the Team entries we seem to have a fair number of Escorts, Cortinas and Falcons. The opposition seems to be mainly Datsun Z's and clubmans. Pictures will follow tomorrow night/Monday.
Next week the Xmas freshen up will start, with the engine, pedal box and front suspension being the main focus.
Here's a few videos. They ran 6 events with a rolling start and approx 6 laps each. My car was quick through the esses and over skyline into colb but as you will see I lacked HP along the straights. As the day went on my lines and confidence did improve...
I have decided to re-fresh the existing car and keep the grey/orange shell duratec project on the back burner for the time being.
On the list is: 1) Freshen up the engine 2) Replace the RD pedal box that is falling apart 3) Change the rear calipers 4) maybe paint
So tonight the engine came out - it's been hemridging oil for the past few events leaving 20cm puddles of oil after a hard run and I’m also getting quite a bit of blow-by into the catch tank now.
It looks like the rear seal:
Two of the clutch center springs were broken and the surface has some wierd marks:
I'll whip the head and sump off tomorrow night and then I'll put together the shopping list. Currently bearings, rings and HP oil pump. I hope their are no nasty surprises inside...
The head is off - good news is 44.5 inlets, and 38 exhausts and good looking ports.
Bad news is 38cc chambers and which seem to give a compression of 12.97:1 which would explain the det I have experienced.
The old head gasket ring measures 1.2mm thick uncompressed - is that safe to use for my calcs, or do they decompress? Whats a safe ratio to run on pump 98ron? If I fit a .080" MLS-5 GASKET it comes down to 11.6:1
Everything else looks fine - the gasket has blown threw two water courses which I suspect shouldn't have been blanked:
Intake:
CC-ing:
Now I need to chase the missing HP since all the components look good on paper...
you wont get an acurate CC reading like that you need to stick a pce of perspex with a small hole in it to fill with on to the head with grease or silicone then fill with brake fluid or glycerine (better than water) all this is to do with the "mamiscous effect" hope i spelt that right
Paul yeah you really need to use a bit of perspex like Steve has said as you wont get an accurate reading otherwise also that isn't a Felpro head gasket and if it came off at 1.2mm thats what it is as they generally stay squashed, with a Felpro it may increase the ratio a little as well
The first time I tried I got massive air bubbles around the outside. I then reversed the perspex and got the same again - so in the picture you can see four smaller holes round the edges which fixed that issue. I'm getting 37 & 38cc on every cylinder using each method. So I reckon it's correct within +/- 1cc
Interesting watching the videos, and how things improved.
I noticed you realised after a few runs that you can carry a higher gear than you initially expect through the left hander up the hill.
I reckon there is time to be gained by braking later into kolb (tricky corner to judge the downhill braking point, where to position the car on entry, and where the apex is) and especially more time on ford fast brake (the one leading onto pit straight) where you can leave the braking until somewhere up the rise into the corner.
Get those two corners right and you make up huge chunks of time.
Now all I need to do is follow my own advice!
Oh and Paul I have a big valve head I no longer need. Would fit your valves - I ran 44.5mm and 38mm in it. Would need a freshen up with valve seats recut but it hasn't been skimmed much if at all. PM me for more info.
If you watch I was being passed about 200m past kolb, and 100m onto the pit straight. It has been suggested it was because I was diving down the inside on brakes and therefore was later on the accelerator out of both corners. The ideal line is a much wider entry, power on early with a later apex - oh well maybe next year!
My 2 week break has been spent mostly non-car focused painting, tiling, roofing, etc. Anyhow today I finally got to do some interesting stuff... I recently bought some new shelving for the shed so had a load of MDF left over so today I built:
It's a two chamber flow bench with a 63mm orifice. Currently it just has the one manometer measuring vacuum but I have room to add a Inclined manometer for better adjustment.
I currently have 4 pinto cylinder heads - so to test the theory I first placed my big valve big port FR32 head with an inlet fully open, and then repeated the test with a standard head, standard cam with an inlet fully open. The small pencil marks on the left are the difference between the two heads.
In proudly showing my wife my new contraption I discovered the old standard head was missing the spark plug So with the plug installed I get 12mm difference in flow which is much better
I have been reading about 10" of water - does this mean 5" each side of the manometer?
First was the inner wing where fuel and oil had removed all the paint:
So a good scrub, etch prime and blow over got it looking good again:
I've also fixed up the bulkhead around the old brake reservoirs, stripped the wiring harness of unused wires and re-taped, and generally fixed up the bay. Pictures will have to follow.
The stripped starter thread in the bell housing has been repaired (steel insert) and I discovered the cable was not pulling straight on the fork so have adapted the plate and made a spacer on the pivot to try and limit the free play.
The new cam, HP oil pump and extractors have arrived. I have put the flow bench to good use and am now happy that the new CNC head is indeed significantly better than my current big port, big valve. I'm still waiting on the machine shop to return the block but at least that is keeping me focused elsewhere.
