tarmac Rally - Cam Selection?
6 posts • Page 1 of 1
Postby PaulMK1 » Wed Dec 07, 2011 9:57 am
Anyone had any experience with the Kent GTS4 cam?
Power Band 3750 - 8250
Cam Lift(mm) 8.25mm Inlet/Exhaust
Valve Lift(mm) 13.69mm Inlet 13.36mm Exhaust
Duration 312 Deg Inlet/Exhaust
Timing 53/79 Inlet 89/43 Exhaust
Full Lift 106 Deg Inlet
VC (mm) 0.25mm Inlet/Exhaust
LTDC 4.70mm Inlet
Engine will have a ported flowed GRP1 big valve head, forged pistons, steel rods and 12:1 compression (needs to run on 98RON)
Any/all constructive feedback will be appreciated :-)
PaulMK1
Re: tarmac Rally - Cam Selection?
Postby Cam » Wed Dec 07, 2011 8:39 pm
Paul T is a Kent dealer. Why not have a chat to him?
Tar's for gettin there, dirts for race'n.
Cam
Postby MK1_Oz » Wed Dec 07, 2011 8:59 pm
That is the cam that I have although I am yet to use the engine. 98RON for tarmac rally in the classic section?? I believe you can use unleaded racing fuel but maybe you are choosing not to....
1970 Mk1 Escort Tarmac Rally Car
Supported By:
Frank Reed Conveyancing
Loving Wife
MK1_Oz
Postby Danny M » Wed Dec 07, 2011 11:56 pm
Paul you really want something with a little less duration say 305-306 with similar figures at .050" and closer lobe centres
Postby PaulMK1 » Thu Dec 08, 2011 9:03 am
Danny, what do you reccommend?
PaulMK1
Postby maxrs » Thu Dec 08, 2011 2:23 pm
Cam lobes should be hitting the spray bar.
Ivan Tye cam. R code for a Pinto. Or
I recommend the cross drilled cams Danny can supply.
maxrs
