  • Board index ‹ Technical - Engines ‹ Cosworth YB
Oil temp
5 posts • Page 1 of 1
Oil temp
Postby Neil S » Fri Aug 10, 2012 8:18 am
I'm am interested to hear anyone else experience with operating oil temp at race conditions.
I have a MkII gravel rally car with a YB Cosworth during long competitive stages the oil temp is getting to 135degC and above.
The temp sensor is mounted in the bottom of the sump
The car has a 12 row oil cooler.
The water temp remains around 95 but in tight stages at high revs might get just over 100degC
I have spoken to a few oil company tech support guys but with no success.
Neil
Neil S
Re: Oil temp
Postby Danny M » Fri Aug 10, 2012 9:27 am
What oil are you using and what is the tempreture that the oil is returning from the cooler back in to the egine with and also how big are the bearing clearences
Re: Oil temp
Postby Neil S » Fri Aug 10, 2012 9:57 am
I have tried a couple of different oils
The most recent was Valvoline Racing 50 It was the closest I could get to the old BP Course Plus and was recommended by the person the i bought the YB of not sure of the tolerances as the motor was second hand built by a German fellow how has returned to Germany.
Prior to that in the pinto we had Castrol Edge 10w 60 and then changed to Castrol Edge25w 50 to try and reduce the oil pressure at this point I had a big end bearing fail but this is when I bought the YB
Not sure of the rerunning temp I have fitted therm o couples to the supply and return lines but have not competed since.
Neil S
Re: Oil temp
Postby Danny M » Fri Aug 10, 2012 10:07 am
How much pressure are you running at idle and at full noise
Re: Oil temp
Postby rs turbo » Fri Aug 10, 2012 6:33 pm
hi mate the oil temp does seem a bit high i have a rx2 that i rally and we dont see that higher temp with a rotor ,i would look at fitting a bigger oil cooler as a starting point ..
Scs automotive
6/32 Currumbin creek road
Currumbin waters 4223
0431649697 Aarron
rs turbo
Return to Cosworth YB
