  • Board index ‹ Technical - Engines ‹ Pinto 1.6 / 1.8 / 2.0 / 2.?
2.1 build
3 posts • Page 1 of 1
2.1 build
Postby beshy642 » Sun Jun 16, 2013 7:59 pm
Guys a mate of mine is looking at doing a 2.1 pinto he can't find a 205 block to start is it possible to use a standard 2ltr block??
Steve B
Mk2 rs2000 4 door auto
beshy642
Re: 2.1 build
Postby MK1_Oz » Mon Jun 17, 2013 11:01 am
my research indicated that there is no benefit of using a 205 block on a normally aspirated engine. In fact, the 205 block is unnecessarily heavier. However, I also found out that the 205 block seems to be able to accept a 93mm bore whereas that bore is very marginal on a standard block. If you are building a true 2.1 then that may require you to use a 205 unless you are stroking it in some way.
The experts will be along shortly to confirm or otherwise.
Re: 2.1 build
Postby Matt1975 » Mon Jun 17, 2013 1:00 pm
Checkout TurboSport. The YooKay boys love offset grinding the crank to get to 2.1 & 2.2
Cheers,
Matt1975
Return to Pinto 1.6 / 1.8 / 2.0 / 2.?
