Now that I have just one Escort project to focus on, it's time to part ways with some of the parts I had put aside for a rainy day and reclaim some space in the garage. Here goes...
Items in red are sold or awaiting payment.
Bilstein Front Inserts
These came out of standard Mk1 1300 struts, but according to the Bilstein catlogue, they suit a range of Escort struts. The Part No. is F4 P30-0101 HO (see attached pdf). The thread on one of the struts is damaged and the top unthreaded section has been cut off, but it should be repairable. I would advise having them rebuilt before putting them into service - $90 the pair.
Escort_Bilstein_Catalogue.pdf
- (37.18 KiB) Downloaded 299 times
Mk1 Steel Front Bubble Arches
Front pair only. Ideal for anyone with a Group Nc race car wanting spares - $450.
Mk1 Fibreglass Bubble Arches
Complete set. Will need a little surface finishing to make perfect. Rear right arch has been trial fitted, so has screw holes in it, but the fit was very good - $250 for the set.
Honda Fireblade Throttle Bodies
38mm throttle plates stepping down to 36mm (might sound small, but think about the choke sizes used in 40mm Webers on a warm engine). 74mm between centres. Can be split into pairs - $120.
2 Litre Escort/Capri Springs
Spring rate unknown and looks like they may have been cut - $10.
Mk2 Panel Van 4 Leaf Springs/Mk2 RS 3 Leaf Springs
Panel van 4 leaf springs - $80. Sold pending payment.
Mk2 RS 3 leaf springs - $40.
Weber 32DGAV
Spanish 32/32 Weber. Brass float. Missing some screws and fuel barbs. Suit rebuild or use for parts - $30.
Mk2 RS Rear Bumper Ends
Not mint, but very good for their age - $90.
Various Parts A
Six Mk2 indicator lenses (5 with housings, 2 with looms) - $15 the lot. Sold.
Two centre console clocks (one missing polished ally surround) - $15 for both. Sold.
Dash vents, carbon canister - Free.
Timing belt cover - Free. Sold.
Various Parts B
Two pairs of Pinto engine mounts - $10 the lot. Sold pending payment.
Pinto radiator fan spacers and fan belt pully - $10 the lot.
4 Speed shifter - $10. Sold.
Two pairs of Mk2 seat rails - $10 the lot. Sold.
Pinto alternator brackets (solid, non bushed) - $8 for both. Sold.
Pinto timing belt pulleys and belt tensioner - $5 the lot.
Pinto thermostat housing (w/o pcv fitting) - $5. Sold.
I would prefer pick up on all items, but I'm happy to discuss postage/courier arrangements.
Feel free to post replies here, however I am not able to access this forum during the day so an email via the forum is probably best, or call 0403 179 073.
All items located in Yarraville, Victoria.
Thanks, Simon.
Feel free to post replies here, email via the forum, or call 0403 179 073.
Thanks, Simon.
