Time to dust it off and pass it on to the next generation!
I am offering for sale my 9/1975 Rally Pack up for sale.
A little history, I bought the car from canberra in 2004 as a rolling shell and built for and CAMS logbooked as a 3j Improved production Car U/2 litre. It has been developed and tested, using info from all the top Improved production escort competitors. On its first outing it won the class 2B in the 2006 NSW supersprint series, it also competed in the 2007 State titles placing 2nd (with Pinto power and missing a round)
It has never been 'raced' but has participated in Supersprints, tracks days and regularity events.
The last outing was at the FOSC Bathurst event in 2010.
Unfortunately it was damaged when a tree branch fell through my garage roof, the car will be sold repaired.
I've not used it in 4 years and it is time to go. It gets run but not driven these days.
Engine/Trans
ST170 motor from an 04 ST170 Focus
tuned twin 45mm dellorto carbs
ashley headers
oil cooler
3 core rad
electric fan
raceline water rail and retroford sump
megajolt crank fired wasted spark ignition (manifold pressure mapped)
Dyno'd to 146rwhp.
Sierra 5 speed w/quickshift
4 puck brass button clutch and heavy pressure plate
1 piece tailshaft
properly welded 4.125:1 diff gears
Suspension and Brakes
300lb front springs with bilstein inserts 2ltr struts
noltec solid adjustable strut tops (large strut tops)
Custom strut tower brace
modified lower cross member (camber only) 3.5 neg camber
whiteline 24mm (?) sway bar
custom 1" dive kit with double mounts
all nolathane bushes
KYB rear competition shocks with 2" lowering blocks
185lb rear springs
BMW e30 vented discs with volvo 4 pot calipers
ebc front red pads
overhauled rear drums with competition lining
Body & Wheels
Largely unmolested 1.3 litre Sep 1975 PRE ADR manual shell,
I consider it to be in very good original condition
The worst rust is in the boot floor (not the wells), there is also some in the rear arches very low and a small patch on the drivers foot well. Floors, rails, plenum, vents and other common areas are clean.
Has a cams registered full roll cage made from the correct steel and certified.
Colour is Tango, and sports rally pack livery, bumperettes and RS2000 rear bar.
Fibreglass replica rally pack spoiler.
Gear lever hole has been modified (for 5 speed)
Interior is basically stripped.
It has some sponsorship decals.
The car has 2 sets of hotwire 13x7 rims, one set is ratty (painted black) the other very good.
Rolls on LOW profile slicks and Scrubbed in only Toyo Proxxes R888's.
SPARES
Doors
Rear Screen
Some interior parts
Bits and bobs for MK2
You can check out a video of the car on song at bathurst HERE,
http://www.youtube.com/watch?v=17oIko1XUA8
the link will take you to other related videos.
Please call me if you want to go racing! or to discuss any further details.
0410 676 774
