Got a great deal on the following front strut combination-
Capri Struts
Coilover conversion
Koni Yellow Shocks
285 lb springs
Eurospeed Eccentric Strut Tops
My question is that the Strut Tops are for a MK I or early MK II with the larger strut top holes.
As I see it I have 3 options -
1. Is it possible to just drill 3 new holes in the shell to fit the larger PCD of the strut tops
2. Have the strut tops drilled to suit the smaller PCD (Not ideal as I may loose a lot of the benefit of the struts tops adjust camber & caster)
3. Buy blank strut tops and have them drilled to suit the Larger PCD. Want avoid this if possible or if somone wanst to do a swapsies that would be cool.
Also will the escort 2ltr hubs fit on the capri struts?
Your opinions are greatly appreciated.
P.S. It wrapped in pink towels for 2 reasons
1. To stop getting crap on them
2. I hated these sheets. Don't tell the wife
