NEED URGENT HELP - TYPE 9 OIL CAPACITY
5 posts • Page 1 of 1
Postby MK2_pete » Tue Jul 12, 2011 8:38 pm
Hey guys as the title suggests I need to find the oil capacity of my type 9 5speed gearbox. I'm assuming its an 'A' as listed on the left side of the main case. any onther info needed?
Any help much appreciatde.
MK2_pete
Re: NEED URGENT HELP - TYPE 9 OIL CAPACITY
Postby ozstang65 » Tue Jul 12, 2011 8:48 pm
Fill it until oil comes back out the filler hole. Don't know the exact quantity..
Postby MK2_pete » Tue Jul 12, 2011 9:02 pm
Type 9 gearbox has two fluid levels depending on the location of the filler plug in side of gearbox. The filler plug itself sits on a raised, oval shape surface.
If the filler plug is at the base of the oval shape, then requires 1.25 litres.
And if your plug is at the top of the oval shape, then it requires 1.9 litres.
Just found this?
MK2_pete
Postby ozstang65 » Tue Jul 12, 2011 10:11 pm
I had one many years ago, don't recall there being 2 plugs. I do recall cutting a hole in the transmission tunnel to get at it though. I thought the casing was the same as the 4 speed.
Postby MK1_Oz » Wed Jul 13, 2011 10:07 am
Mk2_Pete has it right.
Later casings (post 1987) had the filler plug moved 4mm lower reducing the oil capacity to 1.25L
