For the last two events I have random difficulty in selecting 4th. On the highway it's fine but occasionally on the track when shifting up from 7000rpm in 3rd I just can't get into 4th.
I usually do it in a mill bolted to a block If the alignment is out which can happen especially with aftermarket alloy bell housing it upsets the input shaft and synchro alignment and your input shaft is your 4th gear
