  • Board index ‹ Technical - General ‹ Electrical, Ignition & Engine Mngmt
MK1 lotus escort Aftermarket tacho HELP
Postby Bunky Twincam » Wed Jun 19, 2013 1:21 pm
Hello all,
I have bought a SAAS aftermarket tacho, is it possible to connect the tacho trigger wire without having to pull the original dash cluster out?
If not what wire do I connect too, for the aftermarket tacho to work.
Thanks
Bunky Twincam
Re: MK1 lotus escort Aftermarket tacho HELP
Postby ozstang65 » Wed Jun 19, 2013 3:05 pm
Usually the coil -ve side, check if it came with a wiring diagram or perhaps some writing on the terminals on the back of it.
Return to Electrical, Ignition & Engine Mngmt
