  • Board index ‹ Technical - General ‹ Electrical, Ignition & Engine Mngmt
Battery in boot mk 1
4 posts • Page 1 of 1
Postby emil v » Mon May 16, 2011 4:25 pm
Hi,
I need to fit my battery In the boot of my mk1.
The car will be some track and fast road. Basically a club car.
What requirements do I need .
Should the battery be enclosed or can I use a sealed battery (optima) I think they are called.
Remote power switch /isolator and circuit breaker.
Tia
Emil
It might be a small car but its carbon footprint is huge!
http://s5.photobucket.com/albums/y151/viskoe/mexicopy/
emil v
Re: Battery in boot mk 1
Postby mickas » Mon May 16, 2011 5:18 pm
Don't mount it in the boot if you can get away with it. Do you have a passenger front seat? Mount it there if not. There is a lot resistance running the leads that long.
mickas
Postby gen mk 1rs2000 » Mon May 16, 2011 7:05 pm
if you do put it in the boot
dont put it in the wheel well
put it up against the firewall over the top of the shocks
STEVE KING mk 1 rs2000
gen mk 1rs2000
Postby emil v » Tue May 17, 2011 12:51 am
Really wanted to run 2 seats minimum.
havent decided on a fuel tank yet so I wanted to leave some space .
if I use my standard side tank then I will mount it central behind the rear firewall.
Anyone got a pic of their setups so I can get some ideas
thanks
Emil
emil v
Return to Electrical, Ignition & Engine Mngmt
