  • Board index ‹ Technical - General ‹ Body Shell, Paint & Panel
Removing Front Doors MK1 2dr
12 posts • Page 1 of 1
Postby fastlaney » Mon Jun 04, 2012 2:09 pm
Hey guys
cant find any old posts on here.
Just stripping down my mk1 for some panel and paint work. Having dramas getting the doors off.
Are there any particular methods or tricks to getting the pins out? Mine appear to be about 5/16 - 3/8 roll pins. cant seem to get any purchase on them whatsoever
thanks heaps
fastlaney
Re: Removing Front Doors MK1 2dr
Postby Gary P. » Mon Jun 04, 2012 2:51 pm
When I took the door off mine I used a tent peg of the correct diameter then bent the end of it to clear the top and bottom curvature of the door. I had to then keep rebending the peg as I hammered it further into the hinge. It worked really well.
Gary P.
Course Official
Postby fastlaney » Tue Jun 05, 2012 7:59 pm
thanks Gary
sounds easy enough, ill give it a go when I get a minute
Spent today measuring up for all the wood inserts (dash/doors). got a mate who is going to laser cut them out of some plate ally then anodise them. should looks sweet
cheers
fastlaney
Postby Gary P. » Wed Jun 06, 2012 11:01 am
FYI the peg I used was the one that comes with the OzTrail Deluxe shelters. Should be able to get one from your local camping store (BCF ?) Was the perfect diameter and not to hard to bend.
Gary P.
Course Official
Postby PaulMK1 » Wed Jun 06, 2012 1:33 pm
I got a cheap (8mm?) punch from Bunnings. I also soaked the hinges in WD40 for a week or so prior.
On the last shell I got both doors off in less than an hour which I was pretty pround off!
PaulMK1
Postby Gary P. » Wed Jun 06, 2012 2:57 pm
Paul. How did you clear the curvature on the doors with a straight punch?
Gary P.
Course Official
Postby PaulMK1 » Wed Jun 06, 2012 4:45 pm
Bottoms are easy - just knocked straight down and out!
The tops I punched up until they hit the curve of the door. I initially used a crowbar to try to bend the pin until they locked solid, I then used a air hacksaw to cut the hinge pin and then knocked out the remainder (also upwards).
PaulMK1
Postby Gary P. » Thu Jun 07, 2012 10:18 am
Now it makes sense. I was trying to keep the pins intact. I'll probably just use a bolt when I eventually put the door back on.
Gary P.
Course Official
Postby PaulMK1 » Thu Jun 07, 2012 10:28 am
I have always treated the pins as scarificial - 8mm roll pins are cheap. But yes I have used 8mm long shank bolts on both of mine which make future removal very easy! :grin:
PaulMK1
Postby Gary P. » Thu Jun 07, 2012 10:59 am
Unbelievably in the 32 nearly solid years of having an Escort this was the FIRST time I'd ever taken a door off one!!! Not planning on doing it again any time soon either!!
Gary P.
Course Official
Postby fastlaney » Thu Jun 07, 2012 3:17 pm
awesome thanks fellas
hopefully ill get into it tonight
Mark
fastlaney
Postby MK1_Oz » Thu Jun 07, 2012 8:23 pm
I found that WD40 did nothing on its own. I used a paint stripping gun on the hinges combined with WD40. I heated the hinge as much as possible without letting it heat soak into the hinge itself (which would defeat the purpose). I tried a hinge pin removal tool which lasted precisely 3 hits!!!!!!! I then made my own tool out of some 2x1" off cuts with an 8mm steel dowel welded to the front. The extra length made the hammer blows easier. Once heated it only took a few HUGE blows to knock them out.
Horrible job.
Oh, don't dent your sills like I did!!!!
Return to Body Shell, Paint & Panel
