  • Board index ‹ Technical - Engines ‹ Kent - Crossflow & Non-crossflow
head gaskets
3 posts • Page 1 of 1
head gaskets
Postby 356mal » Sat Dec 18, 2010 5:57 pm
can some one please tell me the difference between a
MULTI-SHIM HEAD GASKET and a MULTI-LAYER STEEL head gasket?
is one better or are they both the same?
thanks
mal
COMETIC MULTI-SHIM HEAD GASKET 86mm, X/FLOW, PRE-X/FLOW, BDA, LOTUS TWIN CAM
Description .040"
A surface finish of 50 microinches or finer is recommended for a proper gasket seal. Anything rougher may result in gasket failure.
Part No FB752
COMETIC HEAD GASKET: FORD X/FLOW/LOTUS/BDA 4 CYL 85mm
040" MULTI-LAYER STEEL
part no. C4133-040
http://www.burtonpower.com/catalog/prod ... are/index/
356mal
Re: head gaskets
Postby Momus » Sat Dec 18, 2010 8:44 pm
Same thing.
I've used Cometic and Felpro on Windsor V8's. Check the alignment of the various holes. Spotty QA on some Cometic gaskets.
If there is a Felpro or HKS MLS (unlikely) they might be worth researching.
Good finish on the mating surfaces is important. These gaskets only have a thin rubber layer and are not forgiving. If the block is untouched it should be OK. Some head surfacing is pretty rough; on cast iron I reckon you want a finish closer to ground than flycut.
Momus
Re: head gaskets
Postby Paul T » Sat Dec 18, 2010 11:34 pm
As Markus said they are the same thing.
If your interested I stock them 83-87mm in .040" and .051".
Price is $135
As long as a tip in good condition is used at the correct speed and correct feed the finish will be fine.
Paul T
  • Website
Return to Kent - Crossflow & Non-crossflow
