Clayton wrote:How many turns do you have the idle mixture screws out ??
I've found that I had run the '152' carbs out around 5-5.5 turns to stop the headers glowing at idle, off idle it was fine.
This is on a Pinto, but still should work on a YB.
Clayton
Clayton
i have only ever gone about 2.5 to 3 turns out on the idle screws
never less than 2 never more than 3
Hi Clayton,
I have the idle screw out around 4 turns now for the best idle to date.
I havnt check the float levels as the carbs are new. Never really give it thought.
Dyno tomorrow, so hopefully it will all be sorted. Fingers crossed..
Ian
