Any recommendations for a good place to dyno tune a 2L pinto with carbies in Perth? Think the Delortto's need re-floating or re-jetting as they're running lean. It's back firing on over-run. I could be wrong? I plan on getting some vacuum gauges eventually and doing it myself but just need someone to do it ATM.
Thank you, that's exactly the kind of info I was after. Although I was thinking about it last night after I posted, the car was having charging issues as well, I will have to run it again to make sure it wasn't a weak spark issue.
