Pinto Fuel Selection
i am currently working out (again) what fuel to use in my 'new' 2L pinto motor. The last owner used Avgas and commented that it used to ping (maybe he meant knock?) on 98 octane fuel. The stats I was given with the motor indicate a CR of about 10.5:1. It uses a Kent GT4 cam with webers.
Are there any rules of thumb to determine which fuel I should use based on the above? I guess the options are 98 pump, E85 or one of the 102RON race fuels (exy and the max RON allowed under the regs). I really dont want to have to use expensive race fuel if I can avoid it but I am concerned the motor may not be happy on anything less.
Leaded Avgas is not an option under the regs although I have not investigated the unleaded avgas yet. I recall from a prior discussion that Danny M used 110/130 avgas but do not know if he has since dabbled with unleaded avgas.
E85 might be an option but I am told it does nasty things to carbies?? i assume the jets in the carbies would also need to be changed due to the higher consumption of E85 versus petrol?
I am thinking of pulling the head off to check the compression ratio. Is there anyway of checking if the head bolts are stretch ones or not? Do they appear different? Is a Pinto even likely to use those? (engines are NOT my area!)
