Dynamic compression
Upgrading existing engine for mainly road use, and a few casual trackdays / year. Head hasn't been put together yet, but all is ready for assembly.
Block:
30thou overbore, std rods, std pistons which protrude 0.4mm above block. (block has been machined)
Std Sierra dizzy with elec ignition
Head:
Ported inj head with 44.5 / 38mm big valves (JEM - UK)
48cc combustion chambers after head planing
Newman Ph4 cam (0.474" lift, 275 intake duration)
Newman rockers
40mm twin webers with 33mm chokes.
Matched redline manifold
So this all works out to about a CR of 10.7 with a Felpro HG or 10.2 with a Durapro graphite HG.
So this is all great but when I run the dynamic CR numbers, I end up with a CR of about 8.6:1. This is mainly due to the short duration cam. This seems abit high for cast pistons and pump fuel? Would I be better getting forged pistons, advancing the cam timing, removing more head chamber material or is there a volumetric effiency factor I haven't considered yet and don't need to worry about all this?
Thanks in advance,
Avon
Block:
Head:
Newman rockers
Thanks in advance,
Avon
