RS Motorsport :: Classic Speed Restored • View topic - Flywheel
Flywheel
PostPosted: Thu Jun 29, 2006 3:41 pm
PostPosted: Thu Jun 29, 2006 11:49 pm
Justin,
Please post a picture of the bolt heads.
Of course ARP are well worth paying for when securing a flywheel.
Bolt torques are different for clutch and flywheel. Actual figure depends on bolts and clutch.
PostPosted: Fri Jun 30, 2006 7:32 pm
PostPosted: Fri Jun 30, 2006 8:46 pm
PostPosted: Fri Jun 30, 2006 10:23 pm
John.
Pictured are factory late bolts.
From memory they are marked 12.9.
The earlier ones are 17mm A/Flats and marked either 10.9 or 8.8 cant remember, but will look morrow.
PostPosted: Sat Jul 01, 2006 8:40 pm
Pic of bolts
Pinto Auto flexplate, Crossflow,Pinto early, Pinto late [10.9] So got that mixt up :roll:
Someone has put clutch plate in back to front on early ones and rubbed lettering off bolts
Got some nice ARPs for next time.
Thanks Bruce :wink:
PostPosted: Sat Jul 01, 2006 8:57 pm
PostPosted: Tue Jul 11, 2006 11:51 am
Here is the post machined and balanced flywheel. Original sierra flywheel was 9KG new one is 4.5 KG
An amazing amount of material was removed.
PostPosted: Tue Jul 11, 2006 4:24 pm
by Bruce Phillips
Justin,
I've still got ARP flywheel bolt sets if you need any. I grabbed a few sets from the states while I was there. Also got rod bolts for the YB cossie rods.
Bruce
