2.0L blow through carb setup?
Fri Apr 01, 2011 12:50 pm
by kuzzy
Hi All,
I have had a bit of a look and can't find any info on setting up a SU (or other carby) blow through turbo setup with intercooler for a 2.0L Pinto. Does anyone have any links / photos / articles etc. It is only an idea as I would like to one day build a MK1 2 door RS2000 look alike with a turbo and I think injecting it would lose the period feel / look.
Kuzzy
Re: 2.0L blow through carb setup?
Fri Apr 01, 2011 5:55 pm
by turbodrs
Fri Apr 01, 2011 10:01 pm
Fri Apr 01, 2011 10:50 pm
by kuzzy
Kind of - that is all I'll admit to......
My family name gives me the nick name.
Sat Apr 02, 2011 6:23 am
by joe84
sounds like your setting up a suck thru if it runs an su, i don't know much about settin it up but i do have some parts left over from a suck thru setup 2 carby's, and some other stuff i used the turbo manifold from a blow thru setup tho
Sat Apr 02, 2011 1:19 pm
by kuzzy
Joe84 what you have is a Draw Through setup - carb then turbo.
What I'm chasing info on is Blow Through - Air into Pod filter, turbo, intercooler, carb(s) (modified to handle boost) then engine
Sat Apr 02, 2011 2:04 pm
by joe84
yea i realise that, just never seen an su on anything apart from a draw thru setup, which i thought was the period look, have you looked at an ea falcon throttle body, pretty stealth cheap efi, looks like a carby
Sat Apr 02, 2011 2:17 pm
by MK1 Paul
Blow through carb setup is very similar to suc setup
You need to seal and pressurise the fuel bowl by pumping air from the inlet maifold to equalize fuel bowl 1-1 with manifold pressure.
You also need a rising rate fuel reg and a fuel pump capable of boost pressure plus whatever psi the carb runs on.
ie if the carb needs 4psi fuel pressure n/a plus your running 6psi of boost you need 10psi of fuel pressure and
regulator capable of returning the fuel to the tank.
solex and webbers are popular choices for blow through
and thats about all I really know about blow through turbo setups
Sat Apr 02, 2011 9:56 pm
by kuzzy
I know that the draw through system was all the rage in the 70's, but "the Rover Company (already a builder of industrial gas turbines) built experimental 2.5 liter 4-cylinder turbodiesels (including versions with an intercooler) in 1963". So while not 100% period for an Escort - the basics were there - having said that so was mechanical injection - but I'll put that in the too hard basket.
