Sat Jun 12, 2010 8:42 am
After all that ..................
Make sure u use a condom, else the wipers get damaged.
AND
The taller ones may cause problems at full lift, with retainer.
There's various ones available.
The main thing is fit them to ALL valves to avoid intake dilution and build up on backs of valves etc
Sat Jun 12, 2010 9:44 am
by Avon
Thanks for the tips Roger - I did know about the condom trick but will check clearance at full lift. One annoyance with these sort of vss's is that they are too wide to use dual valve springs with. Prob not an issue to just use the outers only as its only a 280 dur 0.44" lift cam thats going into this one, won't be going over 6000 rpm much as peak power for such a cam I calculate to be about 5700 rpm...
