RS Motorsport :: Classic Speed Restored • View topic - 2 Litre Sump Question
PostPosted: Fri Jul 10, 2009 7:08 pm
by David W
I have 2 sumps - both of which have the same pattern to fit a 2 Litre.
My query is one has a deeper pan then the other - why?
The section that sits behind the crossmember is about 1 inch deeper then the other. One is Stamped FoMoCo & the other is stamped 'Ford'
One is from an original Mk 2 RS motor (smaller one) and the deeper one is from a non RS Motor (sumps could have changed over time so I'm not saying either of these are factory original)
Do these patterns also fit a 1.6 Lt etc?
Can I run either sump in the car & would I need a different oil pick up (so it can go deeper)? Or sump guard??
Seems confusing, but there is probably a sensible explanation
PostPosted: Fri Jul 10, 2009 10:04 pm
PostPosted: Fri Jul 10, 2009 10:09 pm
