A few photos to get started
I did a little work to the head a while ago so it is not as shiny as it could be be. All I have done so far is clean up the throat of the port behind the valve and narrow the valve guide so that it is not so much of an obstruction to incoming airflow. What remains is to do a bit more on the exhaust side and work on the combustion chamber around the valve as there is a step left by the original machining process. Is there any point in polishing the combustion chamber?
Also a photo of the twin 1.75 (44.5mm) inch SU setup on a pinto manifold which I have lying about. Is this just a good door stop?
Regards
Tom
