RS Motorsport :: Classic Speed Restored • View topic - Dellorto Trumpets
Dellorto Trumpets
PostPosted: Sun May 06, 2012 1:26 pm
by David W
I'm chasing a set (4) of 30mm trumpets for my Twin Carbs- Dellorto 40's
Re: Dellorto Trumpets
PostPosted: Thu May 10, 2012 2:14 pm
by gazz
David,
i have a set of 30mm full radius trumpets if you are interested.
http://www.dellorto.com/merchandise/pro ... ctionID=84
they are these ones in silver, which it doesnt look like they make anymore.
i used them for about 2 weeks, still have cork gaskets on them. 1 has a slight dent in it where the bolt from the carb was.
Garry
PostPosted: Thu May 10, 2012 8:31 pm
by David W
Will they fit inside K & N Filters ?
http://www.burtonpower.com/d4030s.html
PostPosted: Fri May 11, 2012 5:18 pm
by gazz
hmmm.... i have no idea. i dont use K & N Filters, but the outer diameter is 88mm if that helps.
let me know
cheers
Garry
PostPosted: Fri May 11, 2012 6:05 pm
by Warren Heath
Do they have to be 30mm long?
I can do you a custon set if required, any length you like
Woz
PostPosted: Sat May 12, 2012 7:14 am
David, check out this one as they are 30mm high......
