RS Motorsport :: Classic Speed Restored • View topic - Mk 2 Escort LSD and 4.1 diff
PostPosted: Wed May 05, 2010 2:48 pm
by Dale Smart
PostPosted: Wed May 05, 2010 8:13 pm
by Belly
go and see Geoff @ Eurospeed Motorsport he should help
0409275149
Belly
PostPosted: Thu May 06, 2010 7:59 am
by Dale Smart
PostPosted: Fri May 07, 2010 9:44 am
diff
PostPosted: Fri May 07, 2010 9:50 am
by Dale Smart
PostPosted: Fri May 07, 2010 10:16 am
PostPosted: Fri May 07, 2010 10:49 am
by Dale Smart
PostPosted: Fri May 07, 2010 12:06 pm
Re: Mk 2 Escort LSD and 4.1 diff
PostPosted: Sat Nov 20, 2010 4:13 pm
by maxrs
What do you do when the Pinto will not rev over 7200.
Run at 150km/h down the straight?
4.11 gears from a early Cortina will fit the Escort center housing.
PostPosted: Sat Nov 20, 2010 4:45 pm
by Dale Smart
Max, I ended up compromising with a 4.4 which seems OK for Lakeside grabbing 5th just before the start finish line. I'm only using 7000RPM as I have no idea how strong the bottom end is. I suspect at Qld Raceway I may run out of puff though. :oops:
PostPosted: Sat Nov 20, 2010 5:44 pm
by escortmk1600gt
Dale,
DM is right, 4.8 is better to start with @7000rpm. I took out a 4.1, as it was waste of time if you want to get to the end of the straight at any track quickly.
David
PostPosted: Sat Nov 20, 2010 5:58 pm
by Dale Smart
Thanks David, DM suggested a 4.9 or 4.7 - is there a 4.8?
PostPosted: Sat Nov 20, 2010 7:46 pm
by escortmk1600gt
Sorry Dale. I now have a Hilux that is 4.8, when I had the English in ran a 4.9. Only recently the sold the english :wink: to Jason Delaney, made his car a little better on lap times. (still needs more though 02cents.gif )
David
PostPosted: Sat Nov 20, 2010 8:21 pm
by escortmk1600gt
Dale a CIG or mini spool would be less $ than a LSD. If its LSD only go for a plate type not ATB DM can advise further
PostPosted: Sun Nov 21, 2010 6:01 am
by Dale Smart
David, thanks again, as per my earlier post I did get a 4.4 plate type LSD built by Deane Buist Palmside in NZ back mid year and have been running Lakeside with it. Based on the advice though I may now build a 4.9 CIG with the original banjo if I can track down a suitable CW&P.
