Mon Aug 24, 2009 6:52 pm
David W,
Where u heading with this modification ??
Mon Aug 24, 2009 8:40 pm
by David W
Its a daily driver. Car has been pulled apart, repainted, rebuild the motor etc etc. As its comes back together I'm upgrading or replacing the bits that need attention (ie: new urethane, brake pads, rebuild mater cylinder, stainless lines etc etc). The car has had camber pins installed at some part of its life and when I pulling the front end apart I noticed the camber pins had a bit of a curve and the thread wasn't 100%. Simple solution (so I thought) - replace them.
I can always fall back to a Std Cross member sitting in the garage
