Shed Clearout - mostly Mk2 Escort stuff
My car is almost on the road and I'm starting to clean out some stuff that is surplus to requirements. I'll add to this over time (after I get the car registered and the garage gets a full clean out). All prices are net of postage/freight.
* Front Kick Panels - Black (no speaker holes) - $40
* Instrument panel - taken from GL Escort (ie: Speedo on RHS and LHS has Temp/Fuel with warning lights inbetween) - $25
* Gutter Mould (Black) - From East Coast Trim in UK - $60. Unused
* RS Centre Caps - set of 4 (Flat ones to suit RS 4 Spoke wheel etc) used $80
* 4 Spoke RS (Sierra?) Steering Wheel - Needs to be upholstered and has paint off - $20 or $40 with boss.
* Lynx Single Side Draft manifold (suit 2 Lt)- $90
* Dash Top Black - taken from Panel Van (will fit sedan's & 2 doors - about an inch narrower). Has a split on LHS of instrument area - was quoted $110 by Plastic repair guy to fix - $40.
* Bonnet Hinges $5 (pr)
* Radiator - $10
* Air Con Compressor - Sanden # CM7863 - New & Unused. Cost $450. Asking $250
* Roof Turret - taken from Mk 2 2 door with Factory Sunroof - $250.
* Drop Tank to suit Mk 2 Escort. Dents in both rear corners - $30. no straps or sender unit.
* Rear Bumper - Chrome with 1 overrider - $10
* Hose winder - previously lived life as a Hot wire mag - 13 x 5.5 with 108 PCD - $5
* Extractors - Suit 2 Litre Pinto. Has crack and needs to be welded - $40
* Rear window - after market tint (Removeable). With or without rear window heater. $20
More stuff to come over the next few weeks - these are the most obvious things I've got (before I start rummaging through boxes).
Any queries - I can be contacted on 0404 890307 or send me a PM
* Radiator - $10
