Stephen Bell MKI Escort Cosworth YB N/A
Here is some more info on the car
and i will add some more photo's soon
Belly
1970 Model MKI Ford Escort
Engine: COSWORTH 2ltr, 16V Twin Cam
Bottom End:
• 205 Sierra Block
• Offset Ground crank (to keep it under 2000cc)
• Datsun L16 Rods
• CP Racing Pistons
• Mellings HP oil pump (with Peterson External Pressure Relief Block)
• Romac Harmonic Balancer
• Datsun L300 water pump pulley
• Hi Volume Custom Sump
PWR Radiator, Speed flow fitting, remote filter housing-peterson
Head:
• BIG N/A Cams - Tighe Cams
• Adjustable Cam Pulleys
• Extensive Porting Inlet & Exhaust, chambers welded up
• Larger Valves
• Soiled Lifter & Double valve springs
• ARP Head, Crank, Big End and Flywheel Bolts
Clutch:
• 7.25inch AP Three Paddle Clutch, Solid Centre - just been rebuilt
• Custom Flywheel, Doweled to crank, (weights only 4.65kgs)
Tran-X Straight Cut Close Ratio Dog Box, Quaife shifter, Alum bellhousing, custom tailshaft
Intake:
• Jenvey 45/51 Tappered Trottle Bodies
• Cosworth intake Manifold
• Custom Ram tubes
• Pipercross Air filter
Exhaust:
• Gonzo Extractors
• Full Mandrel System
BRAKES
• Adjustable Pedal box
Front:
• Volvo Spot Callipers D3000 pads - New
• BMW E30 Vented/Slotted Discs - New
Rear:
• Skyline R32 Callipers and Discs, Alum hats and floating disc - Race products
Diff:
• RN25 Toyota Hilux Diff - Race Products - 2.5 Camber Floating Hubs
• 5.2 Locked Centre
Suspension:
Rear:
• Leaf Springs reset and eyelets reversed
• Koni Adjustable Shocks
• Adjustable Watts Linkange
Front:
• Capri Struts
• Koni 2 way Adjustable Inserts - just been rebuilt
• Adjustable Spring Platforms
• Custom Adjustable Strut Tops - Eurospeed
Wheels:
• 15 x 8 SuperLite all round
• Hancook C71 Race Tyres
Paint:
• Acid Rush (Ford BA) – External
• Blue Print (Ford BA)– Roll Cage
Heaps of Extras not listed
Build Time: 12 Years
Cost: Ask the Wife
Belly
Bottom End:
• 205 Sierra Block
• Datsun L16 Rods
• CP Racing Pistons
Head:
• Larger Valves
Clutch:
Intake:
• Custom Ram tubes
Exhaust:
• Gonzo Extractors
BRAKES
Front:
Rear:
Diff:
• 5.2 Locked Centre
Suspension:
Rear:
Front:
• Capri Struts
Wheels:
Paint:
Cost: Ask the Wife
