RS Motorsport :: Classic Speed Restored • View topic - Twincam suspension re-work?
PostPosted: Tue Aug 09, 2011 8:28 pm
by Bunky Twincam
Hello all,
I am wanting to do some club days and need some info on the below.
Front strut inserts, what brand and from where
Front and rear nolethane bushes, from where.
Front heavy duty sway bar, from where.
Adjustable lower rose jointed arms, from where.
thanks
Re: Twincam suspension re-work?
PostPosted: Tue Aug 09, 2011 10:14 pm
Welcome to the forum.
There is a wealth of knowledge in here and many hours can be spent going through the posts that may be of interest.
My suggestion is to spend a bit of time reading over the old posts in the suspension section as it will give you an idea of what others have/are using and will help guide you on what path you want to go down.
Failing that - Konis up front with adjustable spring palforms and adjustable strut tops, K-Mac 22mm camber adjustable sway bar.
I have heard Nolathane bushes are crap from a few people so maybe super pro is the way to.
Adjustable lower rose jointed arms pop up on ebay quite regularly but you could look at Rally Design or the like.
Good luck
PostPosted: Wed Aug 10, 2011 6:53 pm
This should have information that is applicable to what your after.....
