castor
finished fitting some new bits on the esky. as it sits it has far too much castor. can only turn slightly left or right before the wheel hits the front guard.
i have some compression struts. by fitting them i will gain castor adjustment, correct? i have seen some setups with a sway bar link to the front bolt on the comp strut and up to the swaybar. is this the most desirable setup? also can someone point me in the right direction of how to work out where to fit the other end of the strut.
i am still new to playing with suspension so any advice will be great.
cheers
cheers
