twin cam steering rack
Sun Oct 10, 2010 7:40 pm
by celtic
hey guys,
are the steering rack housings on a twin cam(long stem) and the standard mk1 interchangable? also are the ratios different?my rack is bent from a crash and i havent had a chance to look at both type of racks side by side yet. im sure some of you will have the answer.
cheers.
Re: twin cam steering rack
Mon Oct 11, 2010 6:53 am
by Paul T
Housings are the same ratio is different.
Mon Oct 11, 2010 6:28 pm
by celtic
thanks paul,
do you happen to know the ratios?
i had a look in the ford escort factory manual today,it says that ford used two different companies to supply the racks,Cam Gears and Burman.Cam Gears use a 25 tooth rack and a 5 tooth pinion and Burman have a 23 tooth rack and a 6 tooth pinion .it doesnt specify that the twin cam was fitted with a different ratio though.i took mine apart and it has 25 rack teeth and 5 pinion teeth so i guess its a Cam Gears item.
Wed Oct 13, 2010 9:09 pm
Cam Gear bolts in from the top (same as all Mk2's I think) and Burman bolts in from the bottom. The long steel shaft can be straightened if need be. This might help........
Wed Oct 13, 2010 10:25 pm
how do you shim the t/c rack ?
to get the rack & pinion to mesh nicely ?
ps i do like the grease nipple in the other rack
i have often thought about plumbing the
gearbox breather in to the rack in this spot
just to keep it lubed ?? & gives some where for the
g/box breather to vent .
any thoughts anybody ??
Sat Oct 16, 2010 8:49 pm
