Ideal spring rates?
PostPosted: Wed Jan 25, 2006 12:09 am
by Anthony Tanzer
I have a Mk1 Escort RS2000 replica, and would like to know what the best set up would be for the springs? the rear i am led to believe, works best with a combination of panelvan and sedan springs. However the front seems to have varied responses, would 160lb springs be inadequate for dirt purposes?
PostPosted: Wed Jan 25, 2006 11:39 am
by Bruce Phillips
I run 140 lbs on the front of my MK1, it runs a kent engine so a bit lighter in the front end. I have found these a good rate when it gets rough. 160 lbs should be OK with a pinto I would think.
Bruce
PostPosted: Wed Jan 25, 2006 5:31 pm
by dek
Mark 2 cortina springs were in the back of mine and seem soft enough to really hook up well in conjunction with trailing arms.the front were about 160 with a pinto and seemed to handle well with adjustable castor front bar.
PostPosted: Wed Jan 25, 2006 6:21 pm
RS recomendations.
PostPosted: Thu Jan 26, 2006 7:29 am
by Anthony Tanzer
Thanks Guys!
PostPosted: Tue Mar 21, 2006 9:37 am
by Daniel B
Hope you don't mind me jumping in here Anthony but I also am trying to work out spring rates for my MKII which I have just started Autocrossing.
:shock:
MK2 2.0L Pinto, It currently runs 250lb fronts and 145lb rears, obviously not set up for dirt, would I be correct in assuming that I could just go lower in the front springs, down to around the 150lb as per MK2 RS2000 Gp 1/A/B, and the backs would be fine? Or should I be going lower lbs in the rear as well?
As for shocks the car currently runs the Koni yellows, are these suitable for this purpose?
Thanks, Daniel
PostPosted: Wed Mar 22, 2006 8:19 am
by Bruce Phillips
Daniel,
145 rears may be a bit hard, give it a go but I would think you will find you it best having the rears softer than the fronts say 110-120. Koni yellows should be fine, seen them run on a few rally cars.
Bruce
PostPosted: Wed Mar 22, 2006 10:28 am
by Daniel B
Thanks for that Bruce, will give it a go and hopefully have a bit more control over the car instead of the other way around as it seems to be atm.:oops:
I am glad I don't need to change the Koni's over as they aren't cheap! :grin:
Does anyone have the damper setting specs handy on the Koni Yellow's (they are off the shelf, never been revalved)?
Have never really been able to grasp the whole shocker bump/rebound setup thingy? If anyone knows of any good tech articles I would love to have a read.
PostPosted: Mon Apr 03, 2006 11:07 pm
by Anthony Tanzer
Ok, ended up putting 150lb king springs in the front. :D
The rear springs i've been led to believe will work best by using the main leaf from p/van, cutting the eyes from the sedan next, then the p/van 2nd and 3rd, whilst inverting the 4th and laying it over the top to reduce rebound.
What's the general opinion on this set-up? it seems as though it may be too stiff to me, or does the inverted spring reduce the effect of the 2nd main leaf :?:
Any feedback appreciated.
PostPosted: Wed Aug 30, 2006 10:21 am
by Daniel B
Hi Guys,
It's been a while but i'm finally getting this sorted. I went to get the leaf springs tested and it seems the only place in Victoria I can get it done is over in Dandenong somewhere. Does anyone know of a place over this side of town (Campbellfield or surrounding) where I can get this done.
PostPosted: Sat Sep 30, 2006 9:07 am
by Daniel B
Hi Guys,
Can anyone give me an idea as to what sort of camber, castor, and toe settings I should be trying to achieve for dirt setup :?: and also should this differ for tarmac and if so how :?:
Thanks Daniel. :?
PostPosted: Sat Sep 30, 2006 11:44 am
what are you using the car for
PostPosted: Sat Sep 30, 2006 11:46 am
by Daniel B
autocross atm.
Daniel
PostPosted: Sat Sep 30, 2006 8:37 pm
For the record, RS Group C car runs 140lb rears with 450lb fronts :shock:
Seems to work though. :D
