Hi all thought I would post up my attempts to repair my old mk1 wheel.
I currently have a different wheel on the car but thought it best if I fix the original one up even if it is even just to pass rego.
So I checked you tube and thought why not give it a go.
I used the KBS product Numetal which I had a bit left from other jobs. Its a 2 part expoy that dries rock hard.
This was the state of the wheel prior to starting
So I figured hit it with the sand blaster to get some rust off it, cleanoff some grime and give the epoxy something to key into.
After blasting I got my dremel and cleaned out the grooves in an effort to help the adhesion.
Then I mixed up the last of the putty and started to fill the grooves as best I could.
Over the next coouple of days I will sand it back and prime the rim to get it to look right.
Then I might try and paint the rim to get it to look a bit different.
More updates to come
Happy easter all
Emil
