RS Motorsport :: Classic Speed Restored • View topic - Hydraulic clutch pipe connection
PostPosted: Tue Feb 07, 2012 6:40 pm
by bmw02rally
Guys,
Help needed! Can someone tell me what this connection is on the clutch release bearing pipe outlet?
It looked like a push-fit connection? Where can I get the female end that fits on it?
Re: Hydraulic clutch pipe connection
PostPosted: Tue Feb 07, 2012 7:15 pm
How about doing away with it and putting an AN to flare fitting directly into the housing? Then use a flex hose from there to a fitting on the body somewhere.
PostPosted: Tue Feb 07, 2012 7:20 pm
PostPosted: Tue Feb 07, 2012 7:59 pm
Sorry boss... :axe:
PostPosted: Sat Feb 11, 2012 10:45 am
by Mik Kay
As ozstang has said just replace, its a stupid mondeo connection. Also make sure that the bearing mount pipes are mounted vertically in the box as they wont bleed properly if mounted any other way. I fitted a hydraulic quick connect high on the firewall on mine so i could bleed while out of car then connect when installed.
Mik
