RS Motorsport :: Classic Speed Restored • View topic - Alloy bellhousing
Alloy bellhousing
PostPosted: Fri Apr 27, 2007 8:33 pm
by dek
Just in the process of bolting the engine (pinto) to the gearbox with an alloy bellhousing and noticed that it does not have a have a spacer for the clutch fork only a pin pressed into there .It measures up the same as a standard bellhousing ,The fork i got with it is the same as a standard one.Is there a different fork for an alloy bellhousing or do i tap a thread where the pin was and run the spacer?
PostPosted: Fri Apr 27, 2007 9:07 pm
dek,
Here is correct arm in situ with flat release bearing for UK style pressure plates etc.
PostPosted: Fri Apr 27, 2007 9:10 pm
There is a different fork for an alloy bellhousing but it's mainly different in the shape of the end where the cable goes. As for the spacer, you do not need it. The "height" of the flat section where the fork sits is right for a 2L clutch.
I've both forks in the shed so will take a comparitive photo for you tomorrow.
PostPosted: Sat Apr 28, 2007 10:48 am
by neil
Hey dek, I've got a new bolt and spacer block here if you need em.
Neil
PostPosted: Sun Sep 14, 2008 8:53 pm
by dougo
PostPosted: Sun Sep 14, 2008 9:09 pm
PostPosted: Mon Sep 15, 2008 5:39 pm
by dougo
PostPosted: Mon Sep 15, 2008 6:50 pm
by Bill Hempstead
PostPosted: Wed Sep 17, 2008 2:33 pm
by dougo
