RS Motorsport :: Classic Speed Restored • View topic - Best Size Pipes for a 2L
PostPosted: Mon Feb 20, 2006 10:32 pm
PostPosted: Wed Feb 22, 2006 10:45 pm
by Michael Green
PostPosted: Wed Feb 22, 2006 10:51 pm
by Michael Green
PostPosted: Mon Oct 16, 2006 11:52 am
by Rod Jacome
PostPosted: Mon Oct 16, 2006 10:21 pm
PostPosted: Mon Oct 16, 2006 10:54 pm
by Stu
MY RS2 is fairly mild with a re-jetted 32/36. I use a Bob Holden 'copy' extractors from Rapid Exhausts, Wollongong, and I reckon they do the job really well. Not sure of dimensions but they are a decent size. I had a custom system(2") fitted to my design using as straight a run as possible from the extractors (2 bolt Flange welded on end) to the muffler(single) then over the diff in the standard fittings. I have noticed that this system is the best I've had fitted over the years! I haven't had it on the dyno for any results, but it is better then standard!
PostPosted: Mon Oct 16, 2006 11:24 pm
Way too small guys
PostPosted: Tue Oct 17, 2006 1:27 am
by Stu
What do you suggest Danny? My RS is a road car, daily driver. Would 2.5" be too big? I'm still using the 32/36 carby...
PostPosted: Sat Apr 21, 2007 12:10 am
PostPosted: Sun Apr 22, 2007 1:12 pm
by Daniel H
PostPosted: Fri Apr 27, 2007 9:09 pm
capri v6 mech opening carb is probably a much better option than twin 45,s for all the tricked up road cars .
just copy the formula ford guys with single downdraught weber & all the little tricks they use , they make pretty good economical power for a good road car even a wr 30 cam is perfect all the way to 7
! with a reasonable set of extractors & 2 " exhaust (1 muffler)
lightening the flywheel will help too :wink:
PostPosted: Fri Apr 27, 2007 11:30 pm
by Daniel H
forgot to add running:
12:1 compression ratio
motor was set up for running twin 45's
and running 210hp (unsure whether at the flywheel or at the rears.)
PostPosted: Fri Jun 29, 2007 5:41 pm
by danielmark1
PostPosted: Sun Jul 01, 2007 8:11 pm
