RS Motorsport :: Classic Speed Restored • View topic - Alternator Earth
Alternator Earth
PostPosted: Thu Sep 03, 2015 11:21 am
I have remounted my alternator using a bushed RS2000 style bracket and a nylon adjuster. The alternator is now not earthed and does not charge the battery.
A simple solution is to use a wire between the casing and the chassis/engine. What size wire would that need to be? I guess at least as big as the charging wire?
Are they any other solutions?
Re: Alternator Earth
PostPosted: Thu Sep 03, 2015 12:09 pm
by Scott Morton
I just trimmed down an old battery wire....probably over sized but was just lying around
PostPosted: Thu Sep 03, 2015 5:37 pm
Wire size depends on amps.
Wire from block to alternator case is ok.
Could also use braided strap, but nothing to be gained.
PostPosted: Thu Sep 03, 2015 6:00 pm
Went to the local hills auto bloke and bought a short length of battery cable. I asked him if that was overkill but he was of the opinion that it was the way to go. Anyway, job jobbed.
PostPosted: Thu Sep 03, 2015 7:30 pm
