Hi all, I'm chasing a replacement alternator for the 1600 in the racecar. I'd like to get one with a bit bigger pulley, as light as possible and preferably only with the battery connection (bolt terminal) and indicator light only. Fabricating brackets can be accommodated if required. Only has to run ignition, fuel pump and brake lights so there's not many Amps needed.
Any recommendations on where to get one from would also be helpful.
Scott
