Typhoon ECU.......... Some pointers please
Happy Fathers day Dads.
Being that day, I'm having a play with some new toys, namely the AT Power throttle bodies for the Durascort.
All the hardware installed well, and is a credit to AT Power, they are a beautiful bit of kit. Management for the kit is SC's Typhoon ECU also a good bit of kit, albeit the retard trying to use it. I am just at the point of the initial setup but having difficulties in getting the TPS set to read 0 - 94.95% as instructed in the manual. It seems to be locked on 1.17% at idle position regardless of changes made in the configurable areas. (you'll know what if your familiar with the software)
I'm sure this wont be the only help I need, so I would like to hear from others using this ECU and software.
Thanks Guy's
George.
Thanks Guy's
George.
