Ballast resistors .... and do I need one?
As most people know I am restoring my previous 2L turboed Twin Cam back to original (as near as practical).
Previously ran a $600 plus Inition Developments system (no contact breaker, modern small coil) with a fully stuffed about with wiring loom. This caused probs with tacho and some sort of module was added.
I have since sourced a new wiring loom from 1300GT (only hassle is this ran a generator, but is untouched by fools and has the correct firewall plugs and switches etc.) Plan is to use this with a pertronix breakerless system and a Lucas high energy sports coil (gold with green sticker). A new original tacho has also been sourced.
Apart from above, everything else electrically will be standard.
Today in preparation for replacement of the steering column, I found a small silver block on the bracket that mounts the steering column. It is labled Lucas 4BR and looks like a resistor and is burnt out.
Is this the infamous Ballast Resistor that I have often heard about but never actual seen one (or actually new where it would be).I'm not sure exactly what it does, but I guess that its the sort of resistor that varies with temp.
So, do I need to run this or was this something that was required with 1970's coils. If I dont need one, what mod do I need to make to the wiring loom? If I do need one, has anyone got one?
George
George
