English diff Vs BW78?
Wed Nov 19, 2014 2:10 pm
by ratta tat tat
Hi, Im looking for some advice regarding diffs for Pinto powered MK1 escort road car.
Will a Quaife ATB in an english diff with 'early' MK1 axles (supposed to have tougher splines) be fine for some abuse @ 130BHP?
Also looking at a shortened BW78 from R31 Skyline. How much extra weight would be in this compared to English diff?
I know it's a bit of overkill but I know someone who can do the modification for me mates rates if I supply the diff.
Will there be any classing issues with racing the car if it has an R31 diff?
Thanks
Re: English diff Vs BW78?
Wed Nov 19, 2014 4:39 pm
Bw78 is +20kg.
Quaife would cope with it.
Never broke an axle, just star gear breakage, and short service life on bearings.
Wed Nov 19, 2014 5:18 pm
On a scale of 0 (worst) to 10 (yeeha!) a quaife Torsen diff would rate about 2, if you were lucky (have had one for 10+ years in dad's car). A properly built english diff and clutch plate LSD will handle 130Hp and be your lightest option. Next step would be Toyota Hilux with a good range of ratios available, but your looking at +15kg or so on the english.
Wed Nov 19, 2014 7:37 pm
by ratta tat tat
Thanks fellas. Scott, that's some surprising info regarding the quaife ATB. How does the trans-x LSD compare ? What clutch type centres are readily available for English diff?
Wed Nov 19, 2014 8:00 pm
I have a 3J LSD and have mates running 180+hp using them in race cars with no dramas.
The Quaife would be perfect in a road car though as will be less clunky then a plate type LSD.
Wed Nov 19, 2014 8:38 pm
The quaife might be OK for the road, but you'll curse it the first time you push it hard and it spins the inside wheel. I've no idea what a decent centre is, I've heard Tran-x for the English axle is OK . A large range of ratios is available.
Thu Nov 20, 2014 3:18 pm
by SFE
Both plate type LSD's (examples being 3J & Tran-x) and Quaiffe atb's would handle 130bhp with ease. For a road car punted briskly only on the road the Quaiffe would be fine but on the track once you unload the inner rear you will still get wheel spin. Plate type LSD's are far more suited to the track. 130bhp will hardly tax either, assuming they are assembled correctly and using good oils, just make sure you control any axle tramp. That's the real killer when only moderate power is put through an 'english' axle
SFE
Thu Nov 20, 2014 10:56 pm
by Mik Kay
I have had a tran-x centre with 2 peice axles behind my Zetec for about 3-4 years now and have had no issues. Trouble is from memory this company has now been sold off and cant be purchased ???
Mik
Tue Nov 25, 2014 11:42 am
by Cam
Hey Haydn. I put a BW78 in the rally car and while it's indestructible I wouldn't do it again, it adds to much to the unsprung weight.
Back then there were no options available for the English like there are now . If it were me I'd go for a set of 3J shafts and LSD.
Tue Nov 25, 2014 12:30 pm
When Tran-X closed the CEO went and started 3J and changed the design a bit and have removed a lot of the clunks and clanks. They have a great reputation for a quality product.
I have one in mine and driving on the street you can't hear anything. It has 45 drive, 90 degree overrun with a 65Lb preload. This gives good drive on power (45 degree ramp) whilst still allowing a bit of slip on overrun/cornering so acting like an open diff.
