Hi all, I'm getting the gear ready to install the twin Weber sidedrafts on the crossflow. Does anyone have any suggestions as to a simple and reliable linkage setup to use. The manifold doesn't have any provisions to screw in any linkage supports, however i can probably extend the mounting studs (back towards the engine) and hang something from there if I have to.
I used the Sytec version for 2 years until I started to bend the accelerator pedal - it turned out the syntec rollpin had rusted solid in the linkage, causing everything to bind up.
