RS Motorsport :: Classic Speed Restored • View topic - MK1 Brake Set Up Options
PostPosted: Mon Aug 08, 2011 10:16 am
by markj4770
I am in the process of changing out the braking system, in 2 minds of which way to go. Car is registered, intended for road and club use.
I am interested in opinions of the wise and experienced.
Option1 (most favoured, but not by RTA)
Front
Capri struts, fitted with Volvo calipers and vented disc's, coil overs. Pedal box with 0.750 and 0.700 master cylinders ready to go in.
Rear
Hilux diff, R31 calipers and Audi discs.
Potential Issue with RTA
Running braking system without brake booster seems to upset the RTA inspectors a little. I just picked up a remote booster from a mini, I have read that the twin cams ran a remote booster, can anyone expand on this for me please. How is the booster tied into the brake system?
Option2
Front
Capri struts, fitted with standard M16 calipers, widening kit to accept vented disc's and retain 2lt boosted master cylinder set up.
Rear
I know both options work, there's plenty of chat about these options, I am interested in knowing about the remote booster tying into the option 1 set up. From an engineering point of view, option 1 is far more satisfying, just got to keep it legal.
Thanks Mark
Re: MK1 Brake Set Up Options
PostPosted: Mon Aug 08, 2011 12:10 pm
Hi Mate,
I too am just finishing off the capri / Volvo front and R31 rear disc conversion for a track / club car.
I will just go ahead and do the conversions but keep the standard front struts / brake setup if I need to get roadworthy's etc in the future.
As these cars get older the cops have no idea what's standard and what's not so I think forgiveness is easier than permission.
As to the pedal box I will be using the M/C bolted to the firewall so can't comment on the pedal box.
No matter what you do you'll need to get an approval from an engineer for any brake mods so just depends on how much trouble you want to go to or get into.
Good luck.
PostPosted: Mon Aug 08, 2011 5:16 pm
by markj4770
Thanks Matt, I have spare pair of capri struts waiting to be cleaned up. being a little conservative at this stage might be worth my while.
PostPosted: Mon Aug 08, 2011 10:07 pm
by Paul Dunstan
