Sat Aug 07, 2010 4:29 pm
More mounting points are definitely required as the firewall flexes a lot.
I actually used a MK2 Pedal box as it already has the 4 bolts through the firewall and then added 2 more brackets (2 bolts through each) to the top that then go through the the scuttle(?) and double up as the mounts for the reservior bracket.
Sat Aug 07, 2010 4:54 pm
Thanks for that Gary. Looks quite a simple and logical modification.
My initial thought was to remove the existing square mounting plate that is spotted on the firewall (engine bay side) and replace it with a larger plate. Your method effectively mounts the pedal box to a different plane which is good.
