RS Motorsport :: Classic Speed Restored • View topic - Mk1 escort weight savings with fibre and perspex
PostPosted: Thu May 25, 2017 7:42 am
How much weight can be saved in a Mk1 by replacing all that can be replaced with available fibre glass panels?
Doors, front Guards, Bonnet, Boot, front and rear bumpers and side and rear glass with perspex.
Has anyone done it all and can say it saved 50, 75 or 100Kgs?
Re: Mk1 escort weight savings with fibre and perspex
PostPosted: Thu May 25, 2017 8:11 pm
You need to speak with Steven King
PostPosted: Fri May 26, 2017 5:41 am
How do I do that Danny?
PostPosted: Fri May 26, 2017 8:33 am
I just sent him a message to look here
PostPosted: Sat Jun 17, 2017 6:21 am
bonnet Fibre 6Kg - Steel 14kg
Boot Fibre 4.6 kg - Steel 9kg
Door Fibre 10Kg - Steel 20kg
Arches Fibre 2.5 Kg - Steel 4kg
So looks like about 35.5 Kg available with fibre panels bigger saving with carbon versions but the cost is significantly higher
Smith Deakin list the above parts at £880. Quite steep for a circa 4% weight saving
add lexan and its a grand cost plus paint and maybe 50kg saved or 5.5% weight saving.
its probably a fast enough car without the extra effort and cost.
PostPosted: Sat Jun 17, 2017 7:17 am
The body shell is roughly a couple hundred kg. Skews the % a bit.
PostPosted: Mon Sep 24, 2018 11:38 pm
What thickness are those glass panels though? IIRC the CAMS regs require quite thick fibreglass/composite panels.
