Pre Crossflow head on Crossflow
Hi all...the newbie again....been a while since I played with the amazing Kent engine.....I am sure there will be someone out there much more experienced than self who has done this before and will save me headaches and reinvention of the wheel.
I have a 1600 711M block and am wanting to fit a 1500 pre crossflow head to it ( keeps the general original look of the engine and car)
Given the pre crossflows ran a flat top piston and a dished head design versus the crossflow bowl in piston and flat head.....the question is...what readily available piston do I run that will have similar heights for gudgeon pins etc with a flat top in 83.5mm diameter.
All advice gratefully received.
Doug
Doug
