RS Motorsport :: Classic Speed Restored • View topic - TwinCam weber s
TwinCam weber s
PostPosted: Mon Jun 11, 2007 2:34 pm
to supply the webers on these.........................
The inner rubber has gone real soft etc
What would u do?
Where would you get these re-done etc??
Thanks
PostPosted: Mon Jun 11, 2007 8:19 pm
by Bruce Phillips
Roger Elan factory list them presume they are the same as these ones
http://www.rdent.com/pages/parts.html
TwinCam Weber Fuel Loom
This one's just like the original, with metal banjo fittings and "T" fitting, stainless steel braided hose with crimped hose end fittings and a compression fitting at the fuel pump connection. New banjo bolts and sealing washers are included. Check your old fuel loom regularly for leaks and replace it at the first sign of a problem. A pinhole leak under pressure spraying a fine mist of fuel towards the distributor is a perfect recipe for barbecued Lotus.
Ref. #26L0703 - $179.00
PostPosted: Mon Jun 11, 2007 9:40 pm
Thanks bruce.
What do u think, say Pirtec would do to it.
AND
George will be happy to see these, from your page provided.
http://www.rdent.com/pages/mirror.html :grin:
PostPosted: Mon Jun 11, 2007 10:15 pm
by Bruce Phillips
probably much the same thing, probably who the Elan factory get to make theirs
